Spec me a build
13 May 2009
Stoke-On-Trent
I'm looking to build a new pc, I'm spending around 1300 - 1500, I don't knwo which graphics card to have, i would rather have a EVGA or Asus one, but i don't know i also would like a cheap i7 or i5 for that fact, (could some explain the difference between the X55 or the p55 motherboard) i that they both can hold i5 and i7 just explain the difference between the two please.
also i'm defantly going to buy the sliverstone TF07 case beacsue of the size and the lay and in case i want to liquid cool it can be a very tidy case.
so can someone give me a CPU, RAM, Graphics card (don't mind if ATI or nvidia), hard drive and a power supply.
i would rather have Asus or evga parts as have mentioned above, also i would like to mention that i will be doing a lot of gaming for example supcon full spec and crysis and high or as high as possible
a good spec would be help full thank you Joey
Have a read of the thread in my sig, or at the top of the page, should answer most your questions including a £1500 build
Edit: Whilst Asus and EVGA are good brands the others used are just as good, you can swap the gigabyte UD5 mobo for the Asus P6T deluxe, just get whichever 5970 you can get a hold of, theyre all the same at the end of the day
95thrifles guide is great but if your planning to spend upwards of £1300 why not go for one of OCUK's pre overclocked bundles? Everything you need and if your a noob with overclocking, like myself, you get a stable 4Ghz overclock straight out of the box, I wish id done that in hindsight.
