Dont really know why were arguing but just to make my point
In the other thread the guy stated he couldnt go above 300, where as this OP stated around the £300 mark
The reason I edited the above was because Id selected the 965 in error, making it more expensive than necessary (hence why its now 40 over not 50), Id meant to select the 955 so I amended that
I did not **** off the 640, its a very good cpu, but the 955 is better, hence why I recomended it if the OP can afford to stretch his budget, as I stated if he cant go for the 630/640 it will still give a good machine
I dont know why you appear to be attacking me just because we have different opinions on what would be the better system, we both specced v similar builds, and at the end of the day its up to the OP to decide which he likes the look of, which is why in the other thread I provided links to benches/comparisons so the OP can make an informed choice
Anyway enough arguing with you
To the OP I amended the above to use the 955 instead of 965 as it saves a bit of money and is essentially the same chip, if you want to keep that then you could change the mobo to the following
MSI 770 which will perform just as well but doesnt have the USB3/SATA 6Gb/s, so if thats not a deal breaker it saves you a bit, that and the Sapphire bring you in on budget
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £117.49 (£99.99)
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMD4GX3M2A1600C9) £70.49 (£59.99)
MSI 770-C45 AMD 770 (Socket AM3) DDR3 Motherboard £49.98 (£42.54)
Sapphire Pure 625W Modular Power Supply £46.99 (£39.99)
Sub Total : £242.51
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.00
VAT is being charged at 17.50% VAT : £44.01
Total : £295.52
