Hi,
I have chosen the AMD bundle as it offers excellent value for money and comes with a free SSD which IMO is required for any build these days, 16gb RAM and a fast processor with a respectable stock cooler.
The power supply is a great performer and is backed by a 10 year warrenty.
I have chosen the AMD RX580 so that you can take advantage of Freesync monitors, the rx580 will perform roughly the same as a Nvidia 1060.
The monitor (currently out of stock) has Freesync which will help with smooth game play in the most demanding titles. Its also an IPS panel which will make colours much more vibrant and personally i think they look nicer than TN panels.
An extra 1TB HDD for games and storage, as mentioned a SSD comes free with the core bundle which you would use for OS and applications.
The case is a budget case but it looks nice and looks to have reasonable airflow. ohh and its white
. I have added an extra fan to to increase airflow, place this at the front to suck in fresh air.
The keyboard, mouse and headset bundle are cheap and cheerful, i cant imagine them to be great but they will do for starting out.
This is probably the least colour themed build here as i have focused more on performance and smooth game play. If you sacrifice performance and focus on looks then you may end up with a PC that looks good but is terrible to play games on.
This build assumes you don't need Windows 10, if you do need it there are way of getting it at a very low price, google it.
My basket at Overclockers UK:
