Spec me a cable please
1 Sep 2013
Darwen
Hey guys, im just about to put an order through but have just reliased the pirahna fans im getting are 4 pin pwm but my fan controlled has 3 pin sockets, is there a cable i can get that will connect them together. I cant seem to find one on the site. cheers
would be even better if there is a 2 to 1 splitter as well
You might have a problem with connecting them to a controller mate, I use the 4 pin PWM Vipers in my set up, and tried a controller with them only to find they make a loud humming sound, and when I say loud, it is louder than what the fans are on full. A lot of PWM fans suffer the same problem.
How many do you need to connect ? Because I've just ordered a few of these http://www.overclockers.co.uk/showproduct.php?prodid=CB-070-AK the fans are powered by molex, but you can control the speed via a motherboard header.
I spent ages trying to find a cable and I gave up in the end lol. I had to modify one of my controller plugs to fit another 4 pin fan I have so I didn't want to do that it, tho it does work fine and I can control it. Shame really as I was going to use those fans on my h 80i. Not to worry though as the stock fans are pretty good anyways. Thanks for posting though mate.
