Spec me a camera case?
13 Jun 2009
My own head
For Body + 2 Lenses (not a 300mm fixed!) and accessories.
I'm looking at a Crumpler Cupcake 5500, has anyone else got some good suggestions?
Price range under £60.
what body and which lenses? A D5100 body is smaller than a 5D mk ii for example. Got a battery grip?
Also how many accessories?
Canon 400D (May grab a 5D MK2 at some stage)
No battery grip
Normal lens
75-300mm lens
Also want a wide angle 10-22mm
Accessories - 2 batteries / some cards / cable
+1 the crumpler,
I have one and i love it.
Plenty space for the camera & two lenses and it's comfy to wear while allowing quicker access that a backpack.
I have the 7500 and it's great. Fits my body with lens, two extra lenses (Canon 10-20mm & 55-250mm), battery grip, flashgun and has a little space for accessories.
Agree with the crumpler comments - I have a Daily XL (actually in the MM due to a change in requirement) and it's been absolutely excellent. Good weather protection, easy access, simple to set up and organise, well made and looks good.
Those 5500 and 7500's looks like great compact bags if you need a decent small walkabout setup. :)
How will you actually be using it - any preference to shoulder bag, backpack or the newer slingshot designs?
gt
