Spec me a cannon DSLR with lenes -£1500
28 Mar 2005
Hi all
So my work has moved on and I'm in need of a decent camera to scout with, I will need to take pics of landscapes, houses, rooms, you name it I will prob need to photograph it!
I have roughly £1500 to spend as a max will need a wide lense I assume for rooms etc and maybe a decent zoom lense!
I have been looking at the 550D but not looked into lenses yet!? Is that a good body to be considering for what I need?
That's a great budget - would you consider going second-hand? If so, I'd recommend a 5Dmk2 and 17-40mm f4L. There's plenty around on the Talk Photography classified forums.
I'd consider 2nd hand yes! That's my top top budget I'd rather come in less but I'm easy! Just really need it to take great shots for me lol
so I'm going to head into my local camera store on friday and pic something up brand spanking!
Im leaning towards the 550d as it seems a cheap enough body with more than enough features for me! is it best to stick to cannon lenses? want to bring my budget down by a lot if possible. as i have just decided to move closer to london next month, so want to use the money for part of a deposit!
If your going to be doing interiors, then a FF camera makes more sense :confused:
Slightly more sense but I don't get the impression the OP is looking to be the next famous photographer more just to get the job done for his requirments (bearing in mond the cheap as possible comments) I'd go with
All Second hand
500D - £250
Sigma 10-20mm - £250
Sigma Flash - £100
Sigma 17-70mm (OS Version) - 240
well under budget and more than cover the job!
