spec me a card for under £100
22 Oct 2010
I am thinking of replacing my 9500gt with something a little more up to date.
I dont play anything particularly up to date right now, (world of tanks is my current game of choice) but fancy maybe making it look a bit better (its running on very low settings right now) and having a go with Borderlands 2.
I have a Q8300 chip, with 4 gb ram.
There is a 6xxx card in B grade for 100 notes, is it any good or am I better with either a new 7xxx or a 650?
6xxx what? it matters.
If not save your pennies and get a 7850 2gb. Also upgrade to 8gb ram there's no excuse with prices as they are.
For Boarderlands 2 your better off sticking with Nvidia for Physx, unless you don't care about that?
GTX 650TI: £120, sell the game http://www.overclockers.co.uk/showproduct.php?prodid=GX-202-EA&groupid=701&catid=1914&subcat=2392
You dont need 8gb ram though do you. 4gb is fine for games.
No it isn't. I thought that and was happily running 4gb Radioactive (split from a 6gb tri channel kit). Then I loaded up NFS : Shift and got a really rude message in red text saying I did not have enough memory for my selected settings (8Xmsaa).
Added in another 8gb bringing me to 12gb and bingo bongo, 8xmsaa loveliness.
At £30 or so it's well worth adding more memory if he's on DDR3.
