gotta be a HD3850
To be honest i don't think it will look great on an HDTV. Judging by the size im guessing its a 720p TV? (could be wrong here). And TV's dont always display PC resolutions the same as the TV's native res.
E.g. My 720p HDTV can only do 1024x768 from a PC, so everything looks pretty crappy on it if im running it of a PC.
yes my tv can only do 1024x768 which i was jsut looking at!! which got my brain ticking overtime!!
is it worth going hd graphics card or jsut buy a normal crad which is higher spec?
plus to get full hd quality i would also have to buy a cable to go from dvi to hdmi thus spending more![]()
yes has vga, jsut found manual and had quick look hahaha 1 inch thick book and only 8 pages in english typical!!!
but it did say HD ready but doesnt say 720 or 1080 but does say res at 1366x768.
im thinking now for what im gonna be doing with it maybe HD is abit over the top when i could just buy a normal card????
use component to the tv, or HDMI, then you can enable HDTV resolutions in catalyst to get native 720p
