Back again with a bit more info/research or whatever. Just need some opinions.
I can't go with the HD6970 because it won't fit in the Zalaman
Anyway, need a decent GPU - here are the infos you need:
-Needs to fit in the Zalaman Z9+ (290mm or smaller)
-Gonna be running with a 2500K on Z68 mobo
-Max I can spend is about £250-£300 (cheaper the better)
-Don't want to SLI/Xfire due to the amount of problems
-I have a 600W PSU
-Will be gaming at a res of 1080p on a 22" screen
-Don't want anything overkill, i want to spare as much cash as i can, as long as I can get good performance at 1080p.
So, I was looking at cards like the 560ti 448 editions, HD6950 or the 570... But I need some advice
I think that is all...
Cheers
Cheers.
-I have a 600W PSU
Cheers
Cheers.
