Hi Guys.
I was wondering if you could give me some ideas for some solid cases in my price range? Ill give you some ideas for what I'm looking for in the form of some unstructured rambles.
My idea is to have about 6 fans, 3 intake, 3 exhaust. These will be all hooked up to a fan controller and reduced until nearly silent. (would prefer no pre-installed fan controller as they tend to suck)
Size wise, midi is about right I think, but would consider bigger.
I have a sapphire 7850 (its tiny) so graphics cards size no problem.
full atx mobo support a must (don't care about bigger)
must support the huge cpu coolers (d14, k2 and the like)
don't worry about looks as I'll be the judge of that lol.
needs a nice sound proofing to air flow ratio (if you know what I mean) if its quiet I can have the fans higher for more air flow and if it has good air flow then I can quiet down the fans, so needs to be amazing at one or good at both.
All pre-installed fans will likely be instantly replaced with premium ones so they don't matter.
Any Ideas?
Thanks
Any Ideas?
Thanks
Good thing there's no side window on the R3
