Spec me a case, budget is £55 max.
24 Jul 2004
I had a look at the Lian Li PC-7 PLUS II Aluminium Black Mid Tower Case and I think it's an ok case. It cools well and it looks fine.
I'm just a bit worried about the side casing as my brother has the same model and the side wobbles a bit, seems to be a bit flimsy really.
I'm just looking for other options really.
The case needs to cool well and have a decent airflow, MUST look good and be within £55.
Any help would be great thanks.
I think most people will recommend the PC7+. You have to spend quite a bit more to get a similar case of superior quality.
Rather than just say PC7+ I'd suggest the NZXT Hush Classic. I've got one and it looks great, has good airflow and very good reviews as well.
It's £1.99 over your budget at OcUK though!
