spec me a case for a hackintosh build
  • Thread starter Thread starter 233
  • Start date Start date
233
233
21 Nov 2004
Wishaw
looking for a case for a hackintosh build i'm doing,
ideally something mac pro or mac like :)
any suggestions
What form factor board are you using? I built a G3 case for my little bro with a micro ATX board a couple of years back, worked fairly well but heat is a massive factor.
Saw a great mITX build using a G4 cube if you wanted to go down that route, admittedly they used a low power/heat Via board but a good place to start. I reckon an Atom board with a pico PSU would fit nicely in there. :)
Dell dimension case with a little modding?
