Spec me a case for the Macbook Air 13"
Just been doing some browsing at Apple, seems like loads of the sleeves, if you browse for ones that fit the 13" Air, are the same ones that are designed for the 13" Pro. Don't see how this can be right? I know the Pro chassis isn't exactly huge, but surely an Air would have room to move in one of these sleeves (vertically, if not laterally). For example:
http://store.apple.com/uk/product/H...fnode=MTY1NDA2Ng&mco=MjMzNjkxOTM&s=topSellers
That said, I use one of these for my unibody Macbook and the quality is superb. The use of denim might sound a bit strange, but I was looking for something hardwearing that wasn't neoprene, and it seems like the perfect material. The dark colour helps. The sides are a soft, padded leather for extra protection.
http://store.apple.com/uk/product/T...fnode=MTY1NDA2Ng&mco=MTE0NDAxNDI&s=topSellers
Why are sleeves so expensive...I guess these shops / designers expect people are willing to spend a small fortune on a sleeve if they have just dropped 1k+ on a laptop...
