- 22 Mar 2009
- Cornwall
ok, well was going to hit the order button for the H70 and then thought, actually, will measure just to make sure, and glad i did :
the northbridge HSF is in the way so i dont think it will fit
i currently have GZ-X1 so with the SETTO 1024 being that little bit bigger do you think this would give me the room for better cooler fitments?
although the NZXT Gamma has top mounting fans
so would this be a better one to go for? or does OCUK have anything for ther £30-£50 that is big enough to fit something in with my mobo and ideally has the hole in the back to change cpu fan mounting brackets and has good cable management facilities.
cheers
cheers
