- 18 Oct 2002
- Monmouth
Hi there,
New rig time and I'm looking for a decent case this time as in the past i've had cheaper units to just get my by, ideally it will have a removable motherboard tray to make life easyer when fitting the motherboard with CPU and Heatsink... would like plenty of room so probably full hight? Thats what I'm really not sure of..
Budget is about £100 but can be little over if needed this will be housing a new ivy and Nvidia 680 so if you recommend a case and surgest replacing the stock fans with better ones then I'd be most grateful if you could recommend what fans would be best
Thanks guys!
Thanks guys!
