Hi,
I've had my trusty Antec P182 for at least 5 years now, and since I need a new PSU soon, I've decided it's time for a new case as well.
What I want from a case:
- Easy to build in
- Easy to maintain / clean
- Lots of space for HDD's and SSD's
- Good air flow
- Cable management
- Only need space for 1 optical drive
- Preferably all black in colour and minimal design
Budget is up to £100 but would consider extending if it's worth it.
I've had a quick look on OcUK and found the Cooler Master CM-690 III: http://www.overclockers.co.uk/showproduct.php?prodid=CA-212-CM&groupid=2362&catid=29
Looks good, any other suggestions? Thanks.
- Easy to build in
- Good air flow
- Cable management
