Spec me a case please
13 Jan 2010
Manchester
Hey
Currently I have a old Corsair 800d which is massive and I dont really mind that. But it's not really water cooling friendly, so I modded it to fit all my bits in.
But now I fancy a new cases, I've had it many of years.
ideally my new case will take a 360+240 rads, one in the top and one in the front. No need for any drive bays so my tall tube Res will go there and the pump under the PSU shroud. But I might change the Res to a pump/res combo thingy.
Not to fussed about side window as my pc isn't on show.
Any recommendations?
tia
Does look very smart but could be a little tight for the rads and what not. Signal is poor where I am on my phone so I'll have a proper look later.
Thanks
What thickness rads can you have in this I've got origanal luxe and like this more rad space
Had 60mm in push pull in front
40mm in bottom though pretty much unlimited there
30mm top fans only on 1 side
Top one is only one thickness could
Be an issue to be honest
And yeah got original luxe white
Edition here as well lol
I had a 45mm in my luxe but only just cleared motherboard with fans
Thank you very much your a gent
Lian li lancool ii, loads of room and it don't even come with 5.25 drive bays, it's all set for a 360 rad up front and a 240 on top
They're still adding stuff
In the 20th birthday bash thread
Keep an eye on there
Best I saw so far case wise
Though it's too big for you I know
Was enthoo luxe 2 ~719 at
100 quid for first 10 on the day
At ocuk in person
At ocuk in person
I got this - I wonder if i can fit 2x 480mm rads and 2 x 360mm rads - i know overkill but i wanna
It's possible, though tight
Though will depend on radiator
Thickness, whether radiators have
Extra ports as makes it easier
And what side of radiator you have
The fans on
Ie push or pull
Taking a dremel to the area that
Holds those plastic ssd holders on
Right side of case also improves
Things by just enough to be useful
The fans on
Ie push or pull
thanks man - reserved mines today seems a steal at £100!
