Spec me a case similar size to HP microserver
6 Apr 2009
Liverpool
ive finally got around to improve my server...i have a hp microserver now but use it for other things and its a little slow....so need a case of similar size to a microserver slightly bigger is ok....need to put at least 4 hdd and a ssd in and also a micro atx board ....ive had a look at overclockers not really found anything has anyone got any ideas thanks...
ok so think ive found it....a new case just come out and due in soon what do you reckon on this one my only issue is the power and usb on the side of the case ...
http://www.overclockers.co.uk/showproduct.php?prodid=CA-147-BX&groupid=2362&catid=1850
you can switch the side around so its on the other side (meaning every time you open the case you dont have to disconnect everything)
the case itself will hold 5 3.5" drives & 3 ssd's at any one time (you would lose the space for the bottom 2 fans though) and wouldnt be able to fit a long gpu in the top slot (due to the optical drive bracket which holds 1 of the 3.5" & 1 ssd)
it looks like it going to be a great case though and matx in the size with that many drives would be ace.
