Spec me a case
11 Dec 2006
Birmingham
Hey guys, I've been using the same small case for several years now. I moved to my current case because it looked nice and was cheap, but i've found countless problems with airflow, accessability and build quality. I'm looking to get an upgrade sometime after the new year and want a new case.
I'm planning on getting back into the overclocking scene so airflow and space will be an issue. Initially I will only be using aircooling, but I want to get a case that has space to accomidate a water cooling setup. I don't mind case doors, colour must be grey/silver or black. Looking to spend upto £160.
Thanks =)
If you can stretch another £20 then the Silverstone TJ-09 should be incredibly easy to put water cooling into. The Koolance and Alphacool ready-to-go models are more than you want to spend but they do come with all the watercooling installed already. Even if you don't fancy the Alphacool or Koolance cooling kit, the pictures still give a good idea of what is possible.
Other than the Silverstone;
Lian Li V1200 (lengthened V1000)
Lian Li V1000
Lian Li V2000
Lian Li PCG-70
Akasa Eclipse
Lian Li PC7+
If you pick one of those it won't give you any sleepless nights.
