- 5 Aug 2006
- Derbyshire
I currently have the sonata 2 as my case (see rig in sig). The cpu and chipsetsed heatsink are very hot (cpu idles at 55), and I think this is down to bad airflow in the case, however to me a quiet case is the most important thing, and the sonata 2 is quiet (the rear 12cm is always set to low).
1.I dont want to spend a fortune on a case, as it will only get knocks and dents over time
2. The door snapped off the sonata 2 but its been sorted in the sonata 3?
3.I dont need a huge case, my current one is probs only 40-45cm high, but I do have 5 hard drives and a dvd drive
4.Must be quiet - my sonata2 is with the rear fan on low, but hard drives do vibrate a lot even though there are (crappy) rubber mounts
I really do not know what to get! The antec 900 looks good but surely its loud as there are many fans.
