Spec me a case
11 Jun 2003
Sheffield, UK
Right,
Having a little look around for a new case as i'm rather tired of the dust levels in mine (Antec 900).
The spec:
Dust filters on all intakes
At least 6 3 1/2" drive bays (can live with 5 + 2.5" ssd bay)
Internal 3 1/2 bays should go sideways on to the front (i.e not like the 900 or darkfleet, more like the corsair graphite so with the side panel off they pull out straight towards you).
Interal drives need rubber gromets etc to reduce access/seek noise.
Bottom mounted PSU.
Needs to fit a turniq tower with top and back fans in place.
£120 max
Optional but prefered
At least 2 5 1/4" bays with at least 1 more 3 1/2" external (2 optical drives and the icybox external enclosure with dock). I can live with loosing an optical drive if needed though I guess.
