Budget is up to £230 (would prefer something for around 150 though).
Going to be running crossfire, a big air cooler push/pull, 5 HDD and 2 SSD. So I need something that will fit all them.
Im currently changing from an Antec 902, never again... Waste of space case.
My preference of things I want from a case: (Highest to lowest)
Space (Also includes the cut out for coolers in the motherboard tray)
Cable magement
Cooling
Asthetics
Noise (Currently live with a very loud case so im used to it).
Almost considered a 650D, but from lots of reading the front fans can be a pain to change apparently. (if anyone knows of a easy workaround for that I'd probably buy it).
Thanks.
Cable magement
Cooling
Asthetics
Thanks.
