Spec me a case
31 Oct 2006
Uttoxeter
Hey,
I'm thinking of getting some new pc parts and am also looking into getting a new case. I'm not into watercooling so I want the best airflow possible.
Components
I mean budget wise i don't really wanna go above £200 but well the cheaper the better to be honest.
Thanks
Layout is the same yeah, but can get 600TM with 4 side fans for extra airflow.
Corsair 650D also very good, dunno what the material is off both the 600t and the 650d but the 650d panels are considerably colder than the 600t.
