Spec me a case!
20 Oct 2005
Manchester
Looking to swap into a smaller case using as many of my existing components as I can. Performance is good enough so no real reason for me to go crazy with upgrading parts. Idea is for this to live in the TV area but my Lian Li PC7 is too big and stands out like a sore thumb
I know I'm probably going to have to replace the mobo and CPU due to socket changes etc, but my GPU (GTX 680) has been fine performance wise
Looking to spend £400 for the entire project including new case. The smaller the better really!
Cheers in advance
Fantastic thanks both!
Not sure I have the tools (or the skills!) to cut a case down! What's involved?
Just having a look at the sugo sg05. Seems to require a specific psu but they don't seem to have a huge wattage. Will it be powerful enough to run my quite power hungry gtx 680?
sfx psu's are amazing.
I ran a 970 + i7 at 4.2ghz with a 450 watt silverstone. Recently got a 600w corsair and its fine.
Its only a small amount of cutting, and can be as ugly as you like because it gets covered by the front panel anyway.
