spec me a CCTV system
14 Jan 2010
I'm looking for a CCTV system for a small area of about 6x12 metres and the requirements are:
- minimum of 2 cameras, infrared is not important as area is well lit
- long contuniuos recording, preferbly a minimum of 2 weeks
- videos must be easily transferable to a PC (running windows 7 64 bit) or another storage device should the need arise.
- continous recording is much prefered to motion sensitive, but ideally both is best
-some form of monitor for the system (no bigger then 17" is fine)
budget is about £450
Ive looked at some of the swann CCTV systems, but they have confused me
High Resolution Outdoor / Indoor Package.
This CCTV bundle includes :
1 x Avtech 4 Channel Networked DVR USB, VGA & Remote
1 x Seagate 500GB Hard Drive Installed
2 x 18M DIY CCTV Camera Cable BNC Terminated
2 x 36M DIY CCTV Camera Cable BNC Terminated
4 x 1000mA 12V PSU With 2.1mm Jack
2 x Warning signs pack of 3. Sticky front for windows
4 x Topica Eyecatch Day/Night 20M Infra Red CCTV Camera
also, the camre's in this package have night vision.
LINK:http://www.iviewcameras.co.uk/Avtec...te_18M_DIYBUN-KPD674-13206/version.asp?PID=49
