Caporegime
- 21 Jun 2006
Dahua cameras have always had time issues. A lot of it down to the firmware. Depending who in China you got the cameras of, you could be stuck on a firmware that isn’t upgradeable to the latest Version.
You can set the NTP server address to the IP of your router or use your NVR server ip. Your cameras should not have direct access to the internet.
Wasn't a firmware issue. I had to IP into each camera individually and set and apply the time on each.
So I was doing everything through the NVR which is assigned 192.168.1.9 and asuming it would talk to all the cameras. That wasn't the case.
I had to go into 192.168.1.51 then 192.168.1.52, then 53 and 54 to set the correct time on each individual camera.
All sorted now. Such an easy fix.
I now need to find optimal settings for each camera. I'm assuming I want those at the front of the house recording maximum detail and maximum FPS. The ones at the back I can lower to 15 fps and try and keep the detail max or somewhat high.
