If they are IP rated, why is there a moisture release screw? I’d absolutely love it I’d every time the weather changed the control centre phoned me up and said ‘get the cherry picker out, they’re all misting up so you need to do that thing with the screw’. OK, so NOW I’m being sensationalistbut you get my point. These things should be maintenance free for life. They’re IP rated solid-state electronics.
Anyway, it’s honestly not my intention to have a go at your cameras. If you read my own posts from above, and those of others, you will see that Reolink cameras are highly rated and these are exceptions I’m certain.
I remember I had several jobs to do using Dahua and Hik with over a 150 cams to install and I had to send everyone of them back. At night they fogged up. Complete nightmare. Manufacturing fault at the factory. Cameras were put together in a room with the humidity too high trapping moisture inside the cam. I could easily of fixed them but why should I.
