@Matrix yeah that is correct. Disable the menu below too 'Smart Motion Detection'. Under 'Smart Plan' enable that (box goes orange). Create your rules in the IVS menu.
P.S when you draw your rule for the area you want to trigger the alarm, it's left click to draw and then RIGHT click to confirm it.
P.P.S Make sure you click 'Save' on every page/menu you make a change on. If you don't and you click on another menu, it'll not save your changes!! Caught me out loads..
