Spec me a cheap 4k monitor under £250
26 Sep 2017
In the Masonic Temple
Looking for a 60hz monitor as a second screen for playing single player games in 4k.
Would prefer ips, and also 1ms but understand that's difficult.
So far I have found the benq el287ou which is HDR it says...
And the Asus vp28uqg
Any help would be great as want to get the best I can for my dollars.
Gonna be moving on my IIlyama Prolite B2875UHSU with freesync soon if you are interested in 2nd hand, though it is a tn panel. But it is 1ms. Have a think. Which part of the country is the MAsonic Temple?
Surrey, matey.
I could be persuaded in a second hand one, although I was trying to go for maximum image quality seeing as I wanted it to play single player games, that's why an ips was the favoured
Yeah I can understand the want for IPS now as new they are cheap enough. I was just asking where you are in case you were close to try it on the off chance. I live in South Devon by the sea so it was a long shot as - no one really lives south of me. The quality whilst not bad for a tn is no where near anything like IPS. See whats about though new and weigh up the options. It has freesync going for it and it works under G-Sync with my 1080ti.
I will definitely look out for it, thank you for the suggestion and heads up
