Spec me a cheap-ish case!
14 Feb 2011
Worthing
Currently looking for a replacement case for my spare PC,
It's currently sitting in my old CM 690 II,
which is in a rather decrepit state and slightly stained yellow from an unfortunate water cooling incident.
My requirements are as follows:
Able to fit an ATX board
Have the potential room for a 240mm low profile radiator
Ideally have 2 x 5-1/4" front drive bays for a bayres/pump combo to be fitted.
Not too much of a "Gamer" aesthetic (i.e. Doesn't look like the lovechild of an F-117 Nighthawk and a box of Christmas lights)
No more than about £40
The only other minor requirement, I would prefer actual PCI blanking plates and not those razor sharp shards of metal you have to punch out.
But I could probably put up with them if the price is acceptable.
Any suggestions are welcome!
Thanks for the suggestion, unfortunately I wasn't a huge fan of the case
Ended up getting a Corsair 300R that was surprisingly in budget
