spec me a Chicken recipe!
  • Thread starter Thread starter uv
  • Start date Start date
uv
uv
16 May 2006
Manchester
Howdy :)
I bought a whole uncooked chicken the other day, as it was cheap, but I've no idea what to do with it..
Spec me some chicken food!
pasta, smoked bacon with diced chicken, a mayonaise based dressing with some potato squares in it some garnish and hey presto a delicious meal that will impress. TIP* let it stand for an hour or so, that way the smoked flavour gets rite through the dish.
Must use decent strong flavourd smoked bacon though!
chicken ding....put it in the microwave and when it ding's it's ready....o and dont forget the chips for a great english dinner.
Om nom!
I have some smokey paprika, might give it a go :)
Could do paprika chicken then. Get a big knife and chop the chicken in to quarters. Coat in seasoned flour and fry until golden in a large pan.
remove chicken and set aside. Add a diced onion and fry till softened. Add a can of tomatoes a chicken stock cube and 3+ tablespoons of paprika. Put the chicken back in and simmer for 30 mins.
Serve with pasta (taglatellies(sp) best)
One good sized chicken - chopped up.
2 medium onions sliced
4/5 Cloves Garlic Crushed
1 inch Ginger Crushed
2.5 tsp Salt
2 heaped tsp Chilli Powder
1.5 tsp Jeera (Cumin powder)
1.5 tsp Coriander
0.5 tsp Haldi (Turmeric)
450g~ Yongurt.
Mix the above in a a bowl and chop up chicken. Mix in the chicken and marinade for one hour min.
Then cook on medium heat until the mixture starts to get dry and then about 2-3tbsp of oil (I use 2 tbsp ghee) and start to fry the chicken in medium high heat - add 3-4 chopped chillies after 5 mins.
After frying for 10-15 mins, add two cups of water and cook on medium heat for a further 10-15 mins (sauce should be thick - but not too thick - you can always add more water). Add good amount of chopped coriander and take off the heat.
Eat with rice or naan!
