- 18 May 2010
Hello,
Can anyone advise especially if you’ve been through the same thought process which Chipset to go for specifically a SINGLE GPU build which I find doesn’t seem to be catered for anywhere near as much as SLI/Xfire builds. If I can save £20 by going for a lesser chipset then I can put that towards the case for example.
I will be using an FX-8350 and I really don’t want to lose out on performance from any other aspect if I opt for a lesser chipset than the 990FX.
What I can gather at the moment is that it’s just the GPU support that’s different but I’ve seen a few hints that suggest sound and Hyper Transport differences too, can anyone shed some light please?
Thanks
Thanks
