Spec me a colour MFD printer with two-sided ADF scanning
21 Aug 2006
Hi all
I have looked through the recent 'spec me' threads in here and can't see what I need. I am looking for a home office printer that will do the following:
  • duplex two-sided printing and two-sided scanning
  • 18ppm or higher
  • wireless and wired USB connection
  • print from iOS devices and USB (and SD card a bonus)
  • A4 (would consider A3 if not huge)
  • reasonably priced refills or non-oem cartridges that actually work and last
  • Price range £150-£275
I was considering the Epson Workforce range (in particular the Workforce Pro WF-4725DWF) but it doesn't specify whether any of them will do ADF two-sided scanning. All seem to have fax capability but who needs that these days (or any time in the last 10 years :confused:)...
Appreciate any recommendations.
Brother MFC-L3730CDN.
Does everything you want and its colour laser, so cartridges won't dry out. The toner can be replaced with cheap alternatives. It will have slightly poorer colour reproduction compared to some inkjet printers though is only down side.
After a bit of research I've ordered the Epson WF-7715 which arrives tomorrow, does all of the above and on special at Epson at the moment.
