spec me a comp £930
Permabanned
12 Sep 2005
England
I want a case + everything inside.
I'll like to see my options if I wanted a tft monitor too, how much of a hardware hit i'd take swapping over.
Any suggestions?
I was thinking conroe/ati or nvidia/2gig ram
Not fussed about hdd or cd/dvd drives either so that should help :)
here you go, includes 2gigs RAM, ATi x1900gt(HIS) core 2 duo and is only a little over your budget(£7) be aware the RAM is this week only so if you dont buy it before thursday THIS week it's £30 more, or you could drop to the:
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£139.99 £139.99
which is the same price as the 800Mhz set, but slightly 'worse', hope it looks alright ;)
CA-040-AN Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN) 1
£66.99 £66.99
CP-135-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN) 1
£99.99 £99.99
MB-061-GI Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI) 1
£89.99 £89.99
GX-057-HT HIS ATI Radeon X1900 GT ICEQ 3 SILENT Heatpipe 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-057-HT) 1
£127.99 £127.99
HD-018-SA Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA) 1
£44.99 £44.99
CD-047-LG LG GSA-H22NBAL 18x18 DVD±RW Dual Layer ReWriter (Black) (CD-047-LG) 1
£19.99 £19.99
HS-020-ZA Zalman CNPS9500-AT Aero Flower (Socket 775) CPU Cooler (HS-020-ZA) 1
£29.99 £29.99
FG-024-AK Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan - 3 pin (FG-024-AK) 2
£9.95 £19.90
MY-058-GL GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL) 1
£139.99 £139.99
MO-049-HY Hyundai ImageQuest N91W 19" Widescreen LCD Monitor - Black (MO-049-HY) 1
£144.99 £144.99
Subtotal £784.81
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £12.95
VAT £139.61
Total £937.37
edit: you might also want to upgrade the PSU, but mine is doing 'fine' running pretty close to the above
you specced me with a hdd and cdrom drive :) So remove them and we have more monies to spend on extras :)
Will this pc run vista well enough? (IYHO?)
How will it perform with flightsim x?
didn't notice about the HDD and DVD drive, so use the extra money to get the 22" wide screen belina coming out this month its £199.99,
MO-006-BE Belinea 2225S1W 22" Widescreen LCD Monitor - Black/Silver (MO-006-BE) 1
£199.99 £199.99
Subtotal £199.99
VAT £35.00
Total £234.99
comes to about the same as the TFT i spec'd plus the money saved from the HDD+DVD
it will be more than enough to run vista on :D, it's similar to a lot of other specs people have on this forum, and a lot of them are running the vista beta, so it will be fine ;)
