Spec me a cooler for AM4
1 Dec 2005
Stoke on Trent
Hi all, currently my 1600X is sitting under the stock cooler and its hitting 71C idle.
So im after a new cooler
I was looking at this one https://www.overclockers.co.uk/alpe...ion-dual-fan-cpu-cooler-140-mm-hs-05h-al.html
My case is a Corsair 450D which can apparently take a cooler with a height of 165mm and my motherboard is a Strix B350F
So is the cooler im looking at any good and will it fit? Any similarly priced alternatives?
Seems a bit high for idle temps, maybe try removing the cooler and repasting to see if that improves things before buying a new cooler
There's also the esports duo, which I believe OCUK sells in red. However other colours can be bought directly.
Artic Freeze 2 is the way to go matey. I'm using the 280 and it keeps my ryzen 7 3700x at 65 degrees overclocked 4.4hz whilst gaming. Idle temp at 29 degrees.
Received and installed the freezer this morning along with a 2700X CPU.
Whilst temps are lower than with the 1600X im still seeing idle temps of around 60C.
How tight am I meant to fasten the screws down I don't want to break anything or damage the CPU
