I'm thinking about getting rid of my A64 Pro as it doesn't really cut the mustard when I start putting a lot of voltage through my Opty so I need some suggestions on what to replace it with. The problem is that the width of my case is only 20cm across and I have a 120mm case fan that's right in line with the CPU socket so whatever I choose can't be massively tall. Help!
see review in this section a few threads below!
I hadn't considered the Vanessa tbh, the TT120 would unfortunately be too tall for my case but I think the Ninja should fit hopefully. Original question still stands though with regards to fitting it!
The problem looks to be the NB heatsink, not the height of the cooler so I need one that won't interfere with it -
