Spec me a cooler
19 Dec 2008
Hi Guys
Need a little help, Im after a cooler for my i7, i'm stuck between the corsiar h50, the Megahalems and the Thermalright IFX-14, i've read reviews on all of them and now im stuck
Steve
Same here. I have a Megahalems & I'm very happy with it paired with an Akasa Apache fan. Looking at getting another Apache to run in push/pull now :)
Id suggest the meagahelem or the thermalright ultra. The ifx is overkill for cooling, and the megahelems can block ram slots on certain boards, thankfully my TRUE black on my p6t dlx board still gives me the option of 12 gb ram if i ever need it.
OH by the way im just using the antec 300 case fans inconjunction with the h50. i moved the fan from the rear of the case to the front and fitted the h50 at the rear the case also has a 120mm top fan.
With sharkoon 400-1200 rpm fans (pwm) at 500 rpm, my i7 is idling at 31-27-31-27 at 3.0ghz undervolted at 1.18v core.
