Optronix Midi Tower Case - (Black) 400w PSU (CA-001-OP) -- £26.44 Including VAT at 17.5%
AMD Sempron 64 3100+ 1.8GHz (Socket 754) CPU - Retail (CP-136-AM) -- £70.44 Including VAT at 17.5%
Asus K8N4-E nForce4 4X (Socket 754) PCI-Express Motherboard (MB-125-AS) -- £58.69 Including VAT at 17.5%
GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC) (MY-005-GL) -- £64.57 Including VAT at 17.5%
Samsung SpinPoint P HD160JJ 160GB SATA-II 8MB Cache - OEM (HD-024-SA) -- £58.69 Including VAT at 17.5%
NEC ND4550 16x16 DVD±RW Dual Layer ReWriter (Beige) - OEM (CD-023-NE) -- £29.96 Including VAT at 17.5%
Sapphire ATI Radeon X800 GTO² 256MB DDR3 TV-Out/DVI (PCI-Express) - Retail (GX-101-SP) -- £129.19 Including VAT at 17.5%
TOTAL = £437.71
Right, although a Socket 939 system was *just* in budget I decided you would get more for you money through Socket 754. The CPU should be pretty good and it has more cache than the standard semprons cache of 128. Although the Socket 754 CPU's don't support dual channel, I went for two sticks for upgrades in the future. The PCI-E graphics card is very good for the money and mods very well. I used one of those cases the other week for a friend and was impressed with the build quality and the PSU had pretty decent rails as well
Should also be easy to upgrade as you would just require a new CPU and motherboard to go Socket 939. Should serve you very wel for now though
