Spec me a CPU cooler but...
12 May 2011
Southampton
... it needs to be 'hard wearing' as it be installed and uninstalled regularly. I'm looking to avoid flimsy metal clip things that lose their pull after a few installs.
In the past I've used a Silverstone AR01 which uses rubber mount things and a Zalman CNPS5X which converts intel mounts to AMD mounts and the fan is fixed to the heatsink. Both are pretty good but I am looking to try something new!
Any suggestions? Budget up to £40... Good socket compatibility - 775 to AM4!
