Spec me a CPU cooler.
25 Nov 2006
North Luton.
I'm looking to get a EVGA nForce 780i SLI nForce 780i soon, can anyone recommend a good CPU cooler. I do have thing for the Akasa AK-961, i've got an Akasa Eclipse 62 so size does not matter.
Thanks Marlos.
I have the same case... depending on budget...
Cheap & Effective = AC7 Pro
Best Performance= TRUE
Best value = OCZ Vendetta 2 (half th price of the True but performance is near equal.
do you have a windowed sidepanal or are you planning on getting one?
if not why would the look bother you
tuniq tower 120
true
Noctua NH-U12P
xigmatek HDT-S1283
Seeing as ocuk don't stock xigmatek that leaves you with the noctua which is as good as a tuniq tower or true
is it me or is the OCZ Vendetta 2 a rebadged xigmatek ?
tuniq tower 120 Out of stock, Noctua NH-U12P/xigmatek HDT-S1283 i don't like the look of them.
thanks
