Spec me a CPU cooler
6 Mar 2009
Have overclocked my Q8300 to 3GHz so therefore looking for a good cooler.
I am using speed fan to monitor my temps and under stress with prime95 the CPU sits at around 71 degrees but cores itself are around high 70's to 80's. For example core2 was at 83 degrees.
Have heard good reviews about the Artic freezer 7 pro rev 2!!
What cooler would you's recommend??
