Spec me a cpu cooler
9 May 2005
Devon
Hi,
I am looking for a cpu cooler which will fit in Cooler Master Silencio RC-550 Silent Tower Case. Therefore it can be no higher than 154mm (originally wanted a Silver Arrow but I dont think it will fit, 160mm) . It must be as silent as possible and good for cooling a overclocked 2500k.
I am also not that keen on the liquid coolers and I dont want to spend more than £55.
Thanks
Slack
Thanks for the quick reply.
tbh i skipped coolers like this becuase they seem cheap... However I wont be overclocking the chip to within an inch of its life so a degree here or there wont matter. Therefore this cooler seems ideal for me and its £30 cheaper than the Silver Arrow (which I think would have fitted with a bit of bodging).
SOLD :p
Thanks
Slack
