- 8 Jan 2011
That could possibly accomodate 2 SLI gtx 580s to the loop in the future.
I'd like to equip the Radiator with some Akasa Vipers. I know just a CPU loop may just cope on 120.1 but i've got to plan ahead but here lays the problem.
buying a 120x3 or 120x4 now just for a CPU loop.
I know pumps and reservoirs won't be a huge problem in this as i'll be able to keep them for when the upgrade.
All in all.
Spec me a CPU only Water cooling loop with the possibility of 2 GPU blocks being added. I don't mind buying just a 120.1 Rad for now and flogging it later and buying a 120.4 rad later on if a 120.4 would do for a 3 block loop.
Thanks again OcUK!
*EDIT*! A wild edit has appeared!
I have changed my mind about adding the 2 gpu blocks.
I have taken into consideration that I have the MSI twin frozr II gtx 580 and will get a 2nd and they run super queit. The aim of all this is to get the rig quiet.
So here's my plan:
Get a HAF x with the side Airduct Fan to exhaut hot air from between the SLI gtx 580s. Hopefully keeping them a couple of C cooler (Which a review showed that has reduced 1 5850 in a CF setup by 7c)
Get a small WC loop for my CPU which could keep the Radiator Fan on a super low RPM keeping it fairly quiet.
I think this actually sounds like a good idea. By doing this I could probably eliminate all case fans except the side Airduct on the HAFx and just have the GPU fans + CPU rad fans spinning.
All in all.
Thanks again OcUK!
So here's my plan:
