Right basically I'm looking to get a water cooler soon, I don't have the money nor the expertise to do a custom loop so I want to go for a premade one
I was looking at the raijintek triton because it a lot of tests it performed really well but a) not much stock anywhere and b) a lot of them break so I'm looking for an alternative!
My case supports up to dual 140mm on the top and a 120mm as the exhaust.. Price range wise I would like to keep it under £100
If there's a few any would recommend with pros and cons over each other that would be great!
TL;DR - need a decent CPU water cooler for sub £100
