What is your budget ? this one is £340 brand new
Tube 22" (55 cm) DIAMONDTRON NF-CRT, High-Contrast, Dynamic Focus, Dual Focus Gun, Antistatik- und Antiblend-Coating (ARASC)
Touchtechnology no
Visible working surface (height x width) 304 x 405 mm
Mask width, type Aperture-grill 0.25 mm AG pitch
Horizontal frequency 30 – 110 kHz
Vertical frequency 50 – 180 Hz
Video-bandwidth 280 MHz
Max. resolution/Hz 1920 x 1440 / max. 72Hz
Resolution 1920 x 1440 / max. 72Hz
1840 x 1440 / max. 72 Hz
1600 x 1280 / max. 82 Hz
1600 x 1200 / max. 88 Hz
1480 x 1024 / max. 103 Hz
1280 x 1024 / max. 103 Hz
1024 x 768 / max. 135 Hz
800 x 600 / max. 175 Hz
640 x 640 / max. 180 Hz
Brightness (nominal) 95 cd/qm typisch (nominal)
Apple compatibility compatible
Parameter adjustment Per On-Screen-Display (7 presettings, 10 used-defined memories), 6 languages: D, GB, NL, SV, F, JP
Parameters adjustable sRGB, contrast, volume, brightness, vertical positioning/size, horizontal positioning/size, trapezoid distortion, colour temperature, pincushion, reset, picture rotation, degaussing (de-magnetising), convergence(horizontal and vertikal), parallelogram, horizontal Moiré-Clear-function, pin-balance, zoom, lock function for On-Sceen-Display, OSD-Timer-Function, OSD-Position
Signal inputs 2 x D-SUB mini 15 pin
Power supply 100 – 264 V, 50 / 60 Hz
Power consumption max. 140 W in Betrieb, max. 5 W im stand-by-mode
Power Management VESA DPMS, ENERGY STAR®
Safety CE, TÜV-GS, TÜV (ISO 9241-3/-7/-8), PTB, FCC-B, UL/C-UL (UL60950, UL2601-1), DHHS, MPV (EG Richtlinie 93/42/EWG)
Ergonomics TCO 99, MPR III
Plug & Play DDC 2B™
Measurements (depth x width x height) 493 x 487 x 479 mm
Net weight 28 kg
