Spec me a custom water loop.
17 Mar 2012
Hi guys with xmas coming up im getting a bunch of new hardware and i want to give my system a custom loop, however i dont know where to start or what is good.
I will have room for a 360 rad, it cant have a 5.25" pump/res combo thing, it will have to be internal.
Also im gonna go with rigid tubing and i will heat bend them so no need for a whole bunch of 90 degree fitting.
So basically can you spec me:
360 Rad
Pump
Res
CPU waterblock
GTX 970 waterblock, i have this card.
https://www.overclockers.co.uk/kfa2...ci-express-graphics-card-world-gx-010-gx.html
and all the fittings i will need.
Thanks a bunch.
As for price im not looking for mega high end stuff, more low to mid range.
cheers
Rigidly tubing is nice, but not a beginner friendly endeavour. Don't get me wrong, it's not impossible. Just be prepared for fixing plenty of leaks potentially! Some angled fittings might be desirable anyway,some bends might not be practical or achievable even.
Don't forget to buy tooling for working with rigid tubing.
