spec me a custom watercooling kit??
11 Dec 2005
the mighty hereford
ok nothing hard about this one i just want to cool the cpu as best i can and the most i can spend is 100-120quid
spec me please
p.s i would do it myself but i know nuthing about watercooling
Not sure if you mean which kit or which custom setup? If a kit then I'd recommend the Swiftech H20 Apex Ultra for just the CPU. Or the Ultra+ for the CPU, GPU and chipset (but out of your price range).
thanks but that over budget cant i get the sam performance if i go custom for about 120
also hwo do u determine the size of a tube so for example is a 10/8 bigger than a 1/2
you mean 3/8"?
1/2" is bigger.
its the inner diameter of the tubing
eg:
3/8" is smaller than 4/8" (1/2")
yes im bored
kk thanks could someone advise me on the best pumps and cpu blocks and tubing and resivoir and raiatores to get for a tad over 100
doubt thats possible, the cheapest will push you towards a ton.
if you want to go decent with a custom jobbie, you need to increase your budget.
