Spec me a DeathAdder replacement
18 Oct 2002
Kent
I'm about to RMA my second DeathAdder after it developed the same fault with the left button as the first one so i'm about done with Razer. Apart from the shocking build quality I really like the mouse, the size, shape and weight are all great. So with that in mind if anyone could recommend another mouse similar to the DeathAdder i'd really appreciate it. Max budget is about £60.
Thanks
