So iv decided that my version of quad has a very bubbled heat spreader and will be lapping it shortly ( maybe tomorrow ish), but at the same time i want to get a new heat sink for it for some overclocking pleasure (assuming that the crashing goes).
So OCUK, can you please spec me a heat sink that passes the following criterias :-
It cools very well
Will not colide with surrounding heat sinks on the motherboard (msi p45 platinum)
easy to fit- hoping you wont have to put a harness from the other side
already lapped
price under 40.
Thank you !
It cools very well
already lapped
price under 40.
Thank you !
