Spec me a DSLR
Permabanned
14 Sep 2011
I have only had experience with my Dads Nikon D40
I now want to get my own. I don't no why, but I like Nikon
any suggestions?
I really want to get a bundle if possible.
Budget is around £600
thanks
You'll definitely need a memory card, I personally use Transcend Class 10 cards as they're quick and relatively cheap. Sandisk Extreme are also very good if a bit pricey.
Bag wise I would look at Crumpler, maybe Tamrac or Kata. Although at the moment I'm just using a messenger bag with a padded insert.
Depending on the type of photography you're doing you may want a tripod, landscapes in particular. Manfrotto, Gitzo, Redsnapper and velbon all make good ones. If you want to spend as little as possible the Hama traveller mini pro is only £13 from Tesco and is perfectly usable.
I wouldn't bother with filters unless you want to do long exposure shots or again landscapes, in which case a neutral density (ND8 most likely) and a graduated NG filter would be worth buying. As would a remote release, just get a cheap one form eBay as they all do much the same.
You might want a proper flashgun, but you'll have to spend about £100 to get something decent. The Nissin Di622 is worth looking at.
Thanks again.
I probably will go for the D5100
& prob get it with the 18-55mm VR Lens Kit
All in all, I am prob looking around £700 for that camera with 18-55mm VR Lens Kit, bag, memory card and tri-pod............?
Depends on which bag and tripod you buy, but around that. You can get the memory cards I mentioned for £9 each (8gb). Don't buy them instore, they're always hugely overpriced.
Thanks again.
Don't buy a cheap tripod, waste of money. Save until you can buy a tripod that has some hope of supporting a camera and lens, otherwise they are worse than useless.
The cheapest you could consider 'good' is probably a Redsnapper, which is what I use. The RS-284 and RSH-24 3-way head for just under £60 is a bargain.
The cheaper ones I mentioned are perfectly usable though, for the odd occasion.
Hello,
If HD video is not important to you then the Nikon D90 can be had for a real bargain now.
It is getting on abit now though so the 5100 is also a great choice, its nice to see good advice being given!
What sort of photography are you interested in?
As depending on what you are looking at doing it may be worth going Body only and buying a better lense for the job.
